Dear Gurus
I have the A870 connected to the following as 5.1.2 ( but no sub)
- LR -Floor Standing - B&W 603s 2019 - Set to Large from MLP - Distance 13.6 Feet
- C- B&W HTM6 - Set to Small @ 60 Hz- Distance 13.6 Feet
- Front Heights - Polk OWM3s - Set to Small @80 HZ- Distance 15.6 Feet
- Surrounds - Bose 301 Series V - Set to Small @ 60 Hz- Distance around ( Left 7.4 Ft & Right 5.6 Ft)
- No Sub woofer due to some constraints
For the most optimum settings for Movies i.e Clear Dialogues and reasonable Bass
a. What cross over should i set the speakers to as the YPAO sets the surround speakers to Large
b. For the best Atmos effect, as i cant drill Over the MLP, would it be right to put them as Front Heights
c. Would it make a difference if I place my Speakers as FH BUT in the avr put them as Overhead
d. I have bought a cheap SPL meter for learning- Is this to be used after running the YPAO
Thank you and be safe
Rajesh
