Surround Speaker Question
BD999
I Just moved and unfortunately I am left with a room with three walls to use for my media room. I need some advise on what to use for surrounds. I think I will have to go with in-ceiling speakers due to the rear wall having an art niche. Does anyone have some recommendations for in-ceiling speakers that will match up with the following system or another alternative?
Denon AVR-5700 Receiver
Def Tech BP-30 Bi-Polar Towers
Def Tech C/L/R 2002 Center Channel
Def Tech BPX Bi-Polar Surrounds (replacing)
Def Tech PF 18 Subwoofer
Thanks
BD999
I decided to go with the Def Tech UIW BP/As.
UIW BP/A Specifications:
Mounting Dimensions - Outer Flange Size: 7-1/8" W x
12- 1/2" H.
Cut-Out Size: 6-1/8" W x
11- 7/16" H.
Depth from Flange**: 3-5/8".
Frequency Response: 28Hz — 30kHz.
Drivers: Two 5-1/4" cast-basket drivers with two 1" pure aluminum dome tweeters.
Rec. Amp.: 10 — 250 watts per channel.
Nominal Imp.: 4 — 8 ohms.
Thanks anyway!
U
Unregistered
Guest
like them?
how do you like them? do you have any pictures by chance? do the grills stick out around and inch or are they a true flush mount? i saw them at an Ultimate Electronics and they had a wierd grill on them that stuck out, didn't seem like the quality that def tech would use...
thanks!
Chad
email me at chad.mizner@cmwebsites.com if you happen to catch this... thanks!
