Howdy!
Do some of the sound field options on the Yamaha use the surround backs even if the source material isn't 6.1? I was reviewing my DVD collection and only found a few titles that claimed to be 6.1 and none that were 7.1.
I am just curious how much I am going to get out of them. Since Audioholics chose to use Alan's speaker placement guide as the only one I could find on here, I assumed what he wrote was close to gospel, knowing that each room is in fact different. He even wrote the below in BOLD:
"The main left and right surrounds should be to the respective sides of the listening area, above ear level if possible (ideally 2 feet or more) at an angle of 90 to 110 degrees (see, even Dolby Labs give you some variance) from the front center."
http://www.audioholics.com/techtips/audioprinciples/loudspeakers/hometheaterspeakerlayout.php
Alan's chart shows the surrounds directly facing the listener or up to 110 degrees from the listener. The owner's manual that came with my JBL front speakers also shows the surrounds directly alongside the listener, facing the listener.
I just checked the Dolby site and found that Alan got his charts from there or vice versa. This is what Dolby says about the main surrounds:
"Ideally, your front speakers, high-frequency drivers, or tweeters should be positioned at ear level (when you're seated). Our recommended height for the surrounds is above ear level, as soundtracks are likely to be optimized for that location."
The Dolby site doesn't give suggestions on the surround back speakers other then that they face towards the center but they don't comment on their height, other than there general comments about surrounds being 2 or more feet above your ears.
My ears are just not that finicky, i.e. I can't tell... I am still trying to figure out how much impact the PB-10 has on my configuration. If I can hardly tell I added a sub, you can imagine how little I could tell in a 10-20 degree difference in placement of the surrounds.
Thanks!
Lew
