Hi,
I am getting a 5.1 HTIB and I am a bit confused about what angle the surround speakers should be. I know its meant to be 90 to 110 degrees, but with this in my bedroom where the system is going, I don't think I can do this. If you look at the floor plan of my room, I can't put them to the side of my chair because of the cupboards, and at 110 I would have to put them right in the corner which is againb not possible. What angles should I use or should I just point them at where my head will be?
