This forum is great, everyone he has been so supportive and helpful. Thanks.....
However as I learn more, I learn I really don't know much so here are a few questions.
I have a family room wired for a surround sound system and also 4 additional rooms with 2 speakers each. Ideally I would like to be able to run everything off of one receiver if the cost is not too high.
I was told if I don't want to get a multi-zoned system I could simply hook up volume controls each room (which it is wired for) and turn the volume off where I did not want it. But I would want to watch TV in one room and someone else would want to listen to music in another.
So my questions are several:
1. Is there a receiver say around $500 that would allow for a surround sound in my family room and support 4 additional zones? If so, can you direct me to this product.
2. Would it be better to simply purchase a system that supported A/B speakers and use the A for surround sound and B for the other 4 zones with volume controls in each room? Draw back to an A/B as I see it would be that whatever goes through one channel would go through the other. So if I was watching TV in surround sound, I could not pipe FM radio through the B speakers. (If this is the case that is not a viable option)
3. So, would it be better(actually cheaper) to get a 2 zone system with volume controls? run all 4 rooms off the second zone. Only one or two zones max would be active at any one time. Most likely just one.
4. With all that said, can anyone recommend good flush mounted stereo speakers for the other 4 locations? About $50 each would be my limit at this point.
5. Can anyone suggest a good flush mounted surround sound set of speakers? I need the left/right front/back speakers (4 to be flush mounted). Are these just stereo speakers?
6. In addition to #5 above if left/right front/back are simply stereo speakers, can anyone recommend a good center and subwoofer to go with a recommendation in #5. Or is there a set you can buy that would fit the need? 4 flush mounted a center and subwoofer for a 5.1 setup?
Sorry for the long message,
but basically trying to get a receiver to wire a 5.1 family room and also drive sound to 4 other rooms for stereo (CD/FM listening). Also, need to get flush mounted speakers.
thanks in advance.
