In the case of many systems, particularly
those with little satellite speakers (such
as Polk RM Series products), the low-pass
filter that is built-in to the receiver or
processor is set to the wrong frequency.
Additionally, the high-pass filter that the
receiver imposes on the satellites’ combines
with the satellites built-in filter to weaken
the lower-midrange response of the system
—making male voices sound “thin.”
• The variable low-pass filter (crossover)
adjustment is one of the most useful tools
for adjusting your subwoofer to “blend”
with the rest of the system. By using a prefiltered
signal, you are defeating this excellent
and useful feature.
Some subwoofers (like the Polk PSW650,
PSW450 and PSW350) have “LFE” line
inputs that bypass the subwoofer’s built-in
low-pass filter. This feature is great for
avoiding the double-filter effect when using
a filtered sub-out jack.
The Speaker Wire Advantage
Many people are worried that if they don’t
use the subwoofer output jack, they’ll miss
the Low Frequency Effects (LFE) channel on
5.1-channel DVDs. Not true. We’ll tell you
the secret to getting every last bit of bass,
regardless of which hook up method you
use, in the “Setting Bass Management”
section on page 37.
If you have full size speakers, and if your
electronics allow an unfiltered signal to go
the subwoofer output jack and if the subwoofer
plays in all modes, go ahead
and use the subwoofer output jack.
Otherwise, there are better ways to hook
up your subwoofer.
Almost all powered subwoofers allow you to
connect them with speaker wire. In many
cases, that is the best hook up method
(Fig. 6). If your receiver or processor has
preamp output jacks, use those to feed the
subwoofer using RCA cables (Fig. 7).
When using either of these hook up methods
with a Dolby Digital system, select subwoofer
“off” in the bass management or “speaker
set up” function of your receiver or processor
(see “Processor Configuration and Bass
Management” on page 37). This will direct
all of the bass, including the Low Frequency
Effects channel, to the left and right speaker
outputs and avoid any problems that may
arise from using a subwoofer output jack.
If you have a satellite/subwoofer system with
small satellites, or if you have tower speakers
with built-in powered subwoofers, we strongly
recommend either of these methods instead
of the subwoofer output jack method.
