Hi,
I have some questions about when to use what Surround Sound Format.
My Receiver has the following Surround sound programs: Dolby Digital, Pro Logic II, DTS, DTS 96/24, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1 and DTS Neo 6
When I watch a Stereo TV show, which should I use?:
Use Stereo and hear it on all 6 speakers
Use Dolby Pro Logic II
DTS Neo:6
am I missing something? (something else)
When I watch a 5.1 Dolby Digital surround sound show:
use 5.1 Dolby Digital and just not use the 6th speaker
(Also, if I push the Dolby Digital button again, it somehow makes it 6 channels - how does it do this)
use Dolby Digital EX
use DTS-ES (is it even possible?)
Thanks
I forgot to mention something -
All the TV channels that aren't in HD, still have Dolby Digital - it says DD. The HD channels say DD 5.1. (BTW - I have digital cable). So, does this make a difference as far as what Surround Sound Format I should use? Because it's more than just stereo, it's DD - but is it still just a type of stereo?. So what is regular DD (compared to DD 5.1 and compared to Stereo) and should I use a different type of surround for it?
Thanks
Also - like I said, the regular TV channels have DD, which I assume is still a type of stereo. - So, should I use Dolby Pro Logic II or would DTS Neo:6 be better for those non-5.1 shows?
I would think DTS Neo:6 would seem to be better because it would use all 6 speakers instead of the 5 from PLII ( and since I don't have PLIIx). But, one thing that I saw was this:
One website said:
Dolby Pro Logic II is recommended for stereo and Dolby Surround-encoded VHS movies and broadcast TV programs
DTS Neo:6 is recommended for stereo VHS movies and broadcast TV programs
I noticed that DTS doesn't mention Dolby Surround broadcasts. Is that what I'm getting like I mentioned above with the DD? In that case, would it be better for me to use PLII since it knows how to use Dolby Surround better?
THANKS
BTW - regarding the 5.1 broadcasts - I tried Dolby Digital EX but it sounded worse. It took away some sound from the back left and right to help give it to the rear center surround. Should I just stick with 5.1 or am I doing something wrong?
