does anyone think it would make sense to put in ceiling speakers above the couch for the rears,or is there a better option?
Ok, it seems you really want to add more speakers! Since they simply can't be behind you, but above you, I'd use them as "height" speakers. There are things like Dolby PLiiZ or Yamaha's own algorithm, but I myself would lean towards Audyssey DSX. Of course, to use any of these most likely means you need to buy a new receiver.
If you try DSX, you want them to be at a 45 degree angle, with some leeway. So the heights (ceiling speakers) might very well be closer to the front than the back of your room, lengthwise, depending. There are a number of configurations, but using the 6th/7th as heights (and not widths) would look like this:
here is their own
site (the reading is interesting).
And here is another end user commentary
Audyssey DSX Report.
