I need to decide wiring placement for my HT in the next couple of days.
The position for the projector, screen, front and rear speakers have been decided with no problem. The surrounds do present a problem.
The room will be 19' 8" long by 12' wide.
There will be 2 rows of seats: the 1st is 12' from the front and the 2nd is 16.5' from the front and will sit on a 12" riser. The ceiling is 9' from the floor or 8' above the riser.
I will be using Rocket RS300's, which is a dipole speaker, for the surrounds. Because of a lack of room on the side, I decided that I had to mount the speakers high and angle them down, so people wouldn't hit their heads on them. I decided to place the center of speaker 14" from the ceiling, so that the bottom of the speaker is 6' 2" above the riser.
I wanted to place the center of the speaker between the 2 rows, but closer to the front, so about 13.5' from the front.
However, after doing measurements in the model home, I saw that there was a window on one wall that was 4' wide and went from 10' 10" to 14' 10" from the front wall and the top of the window is 14" from the ceiling. The other side is straight wall and therefore not a problem.
That means the closest that I can put the surrounds is about 15' 9" from the front.
Does this seem like acceptable positioning for surrounds or do I need to come up with a different idea?
Thanks
