I am getting ready to move into a new loft style apt (i.e., open kitchen, dining area and living area) and am putting in a 5.1 system (Energy Veritas V2.3i fronts, V2.0Ci center and V2.0Ri rears/surrounds). Picture a rectangular open area with the kitchen at one end facing the other end (as if the kitchen were one endzone on a football field facing the opposite endzone), a dining area in the middle and the living area at the end opposite the kitchen. The key thing is that the viewing/listening direction is widthwise--i.e., if you are sitting in the sofa, you have windows to your right, bookshelves behind you, plasma in front of you over fireplace, and to your left is open to dining area and kitchen. Hope that's clear enough. The challenge is where to put the surrounds since the preferred position on side walls a bit aft of the listening position aimed at each other is not possible since there's no left wall where the living area is open to the dining area and kitchen and a speaker on a stand there is not an option.
These surrounds are bipolar/dipolar (can be set in either mode...see
www.energy-speakers.com for details on design and how they fire).
So, presumably I will have to put the surrounds behind the sofa facing forward, trying to avoid getting too close to the corner with the right surround. Given that these speakers each fire in 3 directions, will I get a good enough surround effect that way, or should I be trying to design some kind of a swing arm mounted on the built-in shelving behind the sofa that allows the speakers to be swung out and aimed at the listener from 110 degrees or some such?
In general what would you experts do in this situation? Thanks!
