Surround and Rear Speakers: Aim down?
mb66
I must first apologize if this question has been gone over more than once before. I did a brief search and couldn't find exactly what I was lookin for. I would search some more, however I am not being lazy, but I have 3 kids all under the age of 5 that don't like for me to be on the computer. :)
Briefly, my system is going to be setup in a 12'x15' room. The tv is on one of the 12' walls and the couches are 2 feet off of the back 12' wall. the 15' wall to the left is solid, the 15' "wall" to the right is mostly open to the hallway. On the 15' open "wall" I added a header that is 1' tall to seperate the hallway from the living room. The reason I added the header was so that I had a place to mount my Right Surround speaker. I just bought the house and am on a MAJOR budget in the HT department, so I went with the Onkyo ht-530 speakers ($219 to the door, I couldnt resist).
Ok, here is my question: I will be mounting the surround speakers at the recommended degree positions to the listening seat, the surround and rear speakers will both be approx. 3'-4' above the listeners ears. Should the surround and rear speakers be aimed down toward the listeners or mounted flat to the wall? I hope I explained this somewhat clear. Thanks in advance for the assistance, and thanks for the awsome forum to learn from!
L
louhamilton
I aim mine downwards and slightly in front of the listening area.
-Lou
bobbydigital
bobbydigital
I also aim mine downward to the listening position. This sounds best for me for multi channel SACD tracks.
I read in one article I believe on this site that you should try to aim your tweeters at the sweet spot even recommending the use of a laser pointer.
masak_aer
masak_aer
The manual from my HK AVR235 suggest the rear surround pointing to each other flat (4' height), mounted flat. However, I adjusted them slightly with speakers aiming to the seat. The setup produces much clearer and better surround sounds than before. I'd say you turn up the volume about 2 to 3dB higher than the front. I'm new to HT audio so my experience is very much limited. :D
