Suggestions for my JBL speakers?
jad
I've narrowed down for my budget, and based on reviews from here, which speakers i'm planning on buying for my modest home theatre surround setup. I currently have picked out:
JBL e80's for my front speakers
JBL ec25 for my center
JBL e10 for my rear speakers
JBL e150p for my Subwoofer
I'm looking to spend around 300 to 400 on a decent receiver to power these guys. I welcome any suggestions on grood receivers that would fit into this budget. Thanks in advance for any help :)
nav
nav
In that price range I normally recommend the Onkyo TX-SR502 (~$300) or the TX-SR602 (~$400 with a little luck). The former is 6.1, so you'd have an unused channel. The latter is 7.1, so two unused channels which may be used to power a seperate stereo "zone". The only big downside to those two in my opinion is the lack of most pre-outs (obviously, there is the sub pre-out). For the extra money for the TX-SR602 you also (besides the extra channel) get an extra 10W, up conversion to S-Video (not to component), an on screen display (which is only really useful when you're setting the thing up, in practice), and a learning remote (which, in my experience at least, is a little quirky when trying to make it learn).
If the wattage offered by those two is too low, but you want to stick to the same price range, you might want to look at the comparable Yamaha offerings. I don't have their line memorized like I do with Onkyo though :p.
Buckeyefan 1
Buckeyefan 1
If you like Denon, here's a decent buy - I bought my 3805 here as a refurb and it came delivered straight from Denon without a scratch. A few other members did the same with no complaints at all. Dakmart also has good deals on Denons.
www.ubid.com/actn/opn/getpage.asp?AuctionId=10366783
Last week, this receiver went for $462 when they offered a few hundred. Keep this site on your favorites list. This was my "deal of a lifetime" thread last week. A few lucky guys picked one up. Check out the specs and retail price.
www.ubid.com/actn/opn/getpage.asp?AuctionId=800308895
http://us.marantz.com/shop/_templates/Proddetail.asp?model=79&cat=15
