babaseen said:
Hey freemymind...not really the type of reply I was looking for but maybe I rushed to judgement on the type of folks who hang at Audioholics...no offense. Anyway I had the Cambridge Soundworks Subwoofer with the slave but the 801s go as low as any sub needs to, to "rock the room" so there is no need to use them hence they are now taking up space in my basement but once I replace (or sell the 801s), then I will be needing a sub.
Ease up. You asked for help, there's going to be a mix of views and ideas, and ripping into people who reply is not going to get you far.
My advice is, set a budget. I can come up with upgrades for everything you have listed there, but you probably don't want to spend $35,000 on this project. Know realistically what your price range is and what you want to achieve, and then suggestions can be meaningful.
In the absence of that, I'll make general comments. You're presuably happy with the video, and want better sound. The B&W speakers aren't too bad, even at that age, though I'm surprised to hear you say you're happy with the bass. If it was me I'd replace them eventually, but the first thing I'd look at is room acoustics. That's usually the biggest possible improvement, even though it's about as sexy as road kill and takes effort to implement. But if you're serious about improvement, that's step 1.
Step 2 is the center channel, but if you do a lot of HT you usually want the same general sonic qualities in the center and mains, so if you've got the cash, upgrading all three at once might be a good move. I've got opinions on this, but not knowing your room size, taste and budget, I'll keep them to myself.
There's no point in planning past that point, it depends on what you do with 1 and 2. If it's a small room and money is tight, a recent make A/V will likely get you everying you need. If you have space, need power and end up with revealing speakers, a $600 A/V isn't going to make you happy. That's why I don't recommend starting with a receiver replacement. When you get more accurate speakers, you'll just end up replacing the receiver again anyway. Always make inprovements going down the chain: room first, then speakers, amp & pre/pro, then sources. Otherwise, half the time, you don't know what you've done.
