Suggestions for bargain sub w/ built in crossover.
mkinder
I've got an old analog two-channel stereo receiver with a line output for a sub. But since this receiver has no digital bass mgmt, the sub will need to filter out signals it can't handle. So, what are some suggestions for a bargain ($400) sub with a built in crossover? The SVS PB10-ISD was my first choice until i found out it has no crossover and depends on the source to cut out the high's.
I'm afraid my only choices will be to step up to the PB12-ISD which has the crossover, or to buy a used 5.1 receiver and then get the PB10. Either option doubles my budget and puts this whole thing off for a while.
I would prob choose the second option since I don't think I'm getting the LFE track via the analog receiver anyway - which defeats half the fun of having the sub. My room is 14x15x9. I'm hoping there's a great little sub out there i'm missing, thanks for the help.
K
kgb540
You can find brand new Earthquake SuperNova MKIV10's for $349 pretty easily. It is a tremendous performer.
johsti
Do you plan on using this setup for movies, or just music?
If you plan on using it for movies, then I would look at getting a 5.1 receiver for the LFE signal even if you're sticking with a 2.1 setup. Then pick your sub.
If it's for music, than I would look at a good sealed sub and stick with your current receiver. Check out the parts express titanic kits.
mkinder
75% HT/ 25% music. The receiver is an H/K and i've always like it's sound compared to Yamaha, Onkyo and others. Looks like I can pick up a mid-line H/K 4yr old AVR 225 or 325 for about $200. All I really need are Dolby Digital and DTS right?
jonnythan
jonnythan
Yup, as long as it has as many A/V inputs as you need you'll be all set.
bsheldon
If you are absolutely sold on the SVS--I understand. The stf-2 would be my second choice. It doesn't quite have the extension and sub 25hz output as the mighty pb10, but it is as close as you will get under $500. Although It looks as if you may have sold yourself on getting a new AVR anyway--probably the best way to go for 75% HT. You can still use your existing receiver for stereo listening, which you may not need a sub for. If you do get the AVR, the PB10 is the king of sub $500 bass--no question. the next step up (in price) is the cyliders that start at $550--if that is an option. Good luck in your pursuit,
mkinder
After talking to tech support at Hsu Research, it looks like the STF-2 does have a built in crossover and will connect to my current analog receiver. I'll prob go that route and pick up a 5.1 receiver later this year.
Thanks for all the feedback.
