Hi,
Working out the last few kinks on my homemade sub. It sounds great but is a little boomy when playing music in a normal stereo mode. I'm running the pre outs from my receiver to it's amp input (all line level connections). I have the sub's high pass filter set to it's lowest frequency of 40hz. I DO NOT have the signal going back from the sub from the receiver yet. (I'm not sure if I can do that with my Yamaha RXV2500). In theory, the high pass filter should cleanly separate signals above 40hz and send them to my speakers which are good down to about 32 Hz or so. I haven't done this yet because I fear there will be considerable degradation to my main front speakers due to the fact that I would be running them through the sub's $117.00 Chinese manufactured plate amp and a fair amount of cable instead.
Can anyone suggest some sort of variable low pass filter that I can connect to the sub so it doesn't produce frequencies above XX? If there's something out there, I'm pretty sure I can better match my sub to my mains. Any other suggestions?
Thanks,
Greg
