K
kitchen
Hi,
I have prewired my house with 16 gauge speaker wire for the subwoofer. The subwoofer wire is bundled with other speaker wire. What cable is better for subwoofer, speaker wire or coaxial cable? Will the high power(speaker wire) interfere with the low voltage for the subwoofer. thanks for any help
Adam
Adam
Hey, kitchen. From everything that I've read and heard, the coax cable is the better of the two choices. My guess is because it (for one thing) allows for one less filtration step.
In terms of the speaker wire interfering with the low-voltage of the subwoofer, are you asking if the speaker wire would interfere with a coax cable running through the wall? If that's the question, the answer is that a well shielded coax cable would prevent that. If you're asking if you can send a low-voltage signal over the 16-gauge speaker wire while having other high-power speaker signals going over adjacent speaker wire, then there is a possibility of interference. You could always give it a try and see if it there is enough to bother you. When I was getting ready to purchase under-carpet wires for a subwoofer, two different cable companies recommended running flat speaker wire instead of 75ohm coax for the low-level feed. I don't fully understand why, but I think that might apply to your question.
The only time speaker wire should be used with a sub is if you don't have a sub pre-out on your main unit really. In all other cases, coax is the way to go, otherwise you are essentially giving up the ".1" in your system since speaker level feeds will not be bass managed.
Hi,
What kind of sub, passive or powered?
K
kitchen
got coax installed for the sub
Hi,
Finally got the coax cable installed from the receiver to the powered sub. Works fantastic. I bought an onkyo 605 model for $380 US. Now trying to get component cable from the receiver to the 56" TV. I have a 50 ft run from the receiver to the TV. HDMI is too expensive. HDMI is not ready for primetime...
bass addict
Unfortunately the studio's don't share your point of view. I agree it's a quirky system that hasn't been implemented nearly as good as it should have but if you want to take advantage of what the latest formats have to offer, you have to jump on the bandwagon.
K
kitchen
HDMI & component can handle 720p/1080i. My TV can handle max 720p/1080i. Component is more than adequite for what is required. I do need audio to the TV from the receiver since the receiver does 5.1 to the speakers. TV broadcasters broadcast 720p max, they will never broadcast 1080p. So there is not a big benefit for HDMI unless using a blue-ray or HD-DVD with > 60" TV. The prices have to come down for HDMI to see benefits...
Davemcc
Davemcc
I see a noticeable improvement in image quality with HDMI over component on my 720p display. YMMV.
Even my wife can see the difference...from the driveway.:D
