acstech said:
When placing and setting up my sub what should I be listing for? Prior to using a spl meter and my test tones (I will be receiving my Avia disk tomorrow) I had my sub turned up much higher then I have it know and it seemed like it was very boomy and I was hearing bass when I shouldn’t especially while watching cable. After setting my sub with the meter it definitely sounds a lot cleaner but I don't get the rumple I used to during movies. I watched The Island last night and while the bass sounded very clean I never had any rumble. Do I need to turn the volume up on my receiver close to where I had it when I calibrated my system? I have three kids so watching movies at night I can’t crank up the system or my wife will shoot me. I know part of my problem is the sub itself and when I purchase a svs sub it will be a whole new world. I assume when I upgrade my sub I will get both the rumble and clean bass I am looking for. I think my biggest problem is I am just not sure what it should sound like if it is setup correctly. Any help would be greatly appreciated on this subject. I have read many articles on setting up subs but none really talk about what kind of sound you should be looking for. Thank you for your help.
Well, let's see....you turned the bass down, and now you have less bass. What do you expect? With a better sub, properly adjusted, you will have deeper bass if it is in the soundtrack, but the upper bass will be roughly the same. Now, many people prefer having their subwoofer adjusted higher than what would give them a flat frequency response, and if you wish to do that, then that is fine. I personally like having a sub set for a flat frequency response, as I do not like a boomy sound, but many people obviously do like a boomy sound, and they are free to set their systems as they please.
If you wanted, you could set it somewhere in between where you have it now and where it was. I wouldn't, but you are obviously missing loud booms in your soundtracks, and the way to get that is to turn up the subwoofer.
Do you want the sound as close to what was intended as possible, or do you want more bass? Answer that question, and you will have the answer to how you should set your subwoofer.
