That's a negative. If you put something hard underneath it you are likely to get some unwanted resonances. So basically, you'll be boosting certain frequencies while the other's remain the same which is exactly the opposite of what you want ideally. Ideally you want a flat frequency response from the sub, it is likely you won't achieve without room treatment, but you will definitely get further away by doing what you suggested.
