Hey guys,
I've just finished building a 5.(1) system and now need a subwoofer recommendation!
My system is as follows:
LCR: Ascend Sierra -1s
Surrounds: Ascend HTM-200se
Pioneer 1222K
My living room is about 1500 ft^3, hardwood floors and has open door ways to two rooms.
Size is not too much of an issue as I have a good space for in between my couch and loveseat.
I do about 80% music/ 20% movies. Since I do mostly music, I think I want more of a musical sub than a HT sub, but would like to get a sub that can handle both music and movies for when I do watch movies to make my 5.1 system worthwhile.
I'm trying to spend under $700 shipped for a subwoofer and after doing some research have come down to a couple options:
HSU STF2
HSU VT1- MK4
HSU VT2- MK4
Rythmik F12
Rythmik F15?
a SVS subwoofer in this price range.
I know the Rythmik F12 will run more than my budget, but Ascend sells them and I think they may be the best match for my speakers. I also get a 5% discount with Rythmik for ordering a HT speaker setup through Ascend
I don't really know much about subwoofers, but from what I've read, sealed subs are better music subs as they are tighter, and ported subs are better for movies as they have better low end extensions and louder.
Seems that the HSU subs get very high recommendations and are less expensive than the Rythmiks. Are the Rythmiks a step above the HSU subs to be several 100 more than them?
What do you guys recommend for my situation?
