Invest $50 in SPL
Hi, i have the following speakers Onkyo SKS-HT540 minus the sub. My new sub is the Definitive ProSub800. My problem is after running the auto setup with my Onkyo 606 it sets the Sub to -11db. My sub is 8ft away from the listining position. I did set the volume to half way before running the setup. I was reading how the sub should be louder than the mains like 3db higher.
This what the auto set up:
Front 80hz
Center 80hz
Surround 120hz
Lpf of Lfe 120hz
On the back of the sub i have the crossover all the way up to 140hz.
Any help would be great.
Auto setup is fine as it goes. the -11dB can be manually changed, either by increasing the gain on your AVR or the sub. You can adjust the sound level by ear. Remember this is just a starting point and one reason for the -11 dB on the sub is that the sub is usually self powered and the rest of the gain is coming form the sub amp. so -11 db compared to the other speaker levels is somewhat meaningless.
However, the best way I have found it to get a $50 SPL meter and adjust all of the levels of the speakers equal by using a reference sound level, say 85 dB from the listening position . Then adjust the level of the sub hot by +3db to +10 dB. ( typically higher for explosions, gun shots and other movie rumble and DVD watching, typically lower or flat for music... but it is your preference). Radio Shack dB meter :
http://www.radioshack.com/product/index.jsp?productId=2103667
Set you speakers to "small" on your AVR (this acitvates the sub crossover) and set you crossover frequency much lower than 140 Hz --- usuallly somewhere around 80-100 Hz
Good Luck!
MidCow
