SUBWOOFER PLACEMENT #2
memanuel70
Placement issue also.......i would like to do either mid wall placement of two subs or diagonal placement for two subs, only issue is that to do midwall placemnet becuase of funiture can not put on perfect midwall, could subs be placed diagonal on front and back wall instead of side walls , or to diagonal i can only do the one sub right side of room against wall the back left side room sub can not side against wall due to furnitre again. Any ideas or suggestions, thanks.
shadyJ
Speaker of the House
Staff member
You should just go with whatever sounds best to you. We can not predict the response of the subwoofer simply from your description. Try the subs in all those locations. If you do not have a way to take measurements, use a filtered pink noise tone like this, and keep the placement that sounds the 'fullest' with that noise.
