No.1: I see what you mean, but all i can find is 2.1, 3.1, 5.1 and 7.1 modes on the receiver
No.2: I just set it up in 2.0 mode, at least im 90% sure its in 2.0 mode because on the computer i go to test the speakers, it shows left and right speakers only. no centre etc. so it must be in 2.0 mode correct? also: the sound management console on my computer is Realtek AC97 audio, it features 2 channel mode for stereo output, 4 channel mode for 4 speaker output and 6 channel mode for 5.1 speaker output. so i chose 2 channel mode.
i forgot to mention that the sound card is the onboard motherboard sound. its not an aftermarket product.
so i found the manual in pdf format..
and by the looks of it my sound card DOES support 6 channel audio??: this is what it says in thr 6.1 section:
"Use the back audio panel to connect the audio output
without any additional module.
STEP 1:
Connect the front channels to "Line Out",the rear
channels to "Line In", and the Center/Subwoofer channels
to "MIC In".
and the 2 Channel mode:
"Connect the stereo speakers or earphone to "Line Out."
Conclusion: so right now, im using the 2 channel mode which is ONLY for left and right and NO subwoofer.. and what im guessing is: to be able to hear the subwoofer, i need to do the 6 channel mode..
@ Adam. haha thanks man i love the trademark symbol for some reason !! i dunno why. i just like it
EDIT: i think that the subwoofer isnt working because simply the Amplifier doesnt support the way ive connected it to the computer and therefore only lets front work?? one thing i dont understand: the computer is set in 2 channel mode, when i press 5.1 on the amplifier remote, all speakers respond except the subwoofer. how can this be when the computer is in 2 channel mode :S..
until i figure out the problem, i have turned loudening on the amplifier which sends out more bass sound..
