Subwoofer Low Pass Setting
Isosevodes
Isosevodes
Is it wise to put a subwoofer’s Low Pass Setting on Bypass when watching Home Theater or listening to Music? Does this maneuver result in the receiver deciding which frequencies are directed to the sub? Won’t you get the exact same result if you turn the Low Pass to your subs MAXIMUM Hz and adjust sub GAIN/Volume to your liking? Is this common practice? I am obviously totally confused here! BTW literature accompanying the RSL Speedwoofer 12S suggests initial GAIN of 50% and Low Pass BYPASS for Movies and 80 Hz for Music. Why not 80Hz for both Movies and Music? Please advise. Thank you.
isolar8001
isolar8001
Many 2 channel amps don't have a crossover/bass management at all. In that case, those with stereo only units definitely want to use the Low Pass on the RSL turned on and set to at least 80hz.
Those using multichannel AVR's just need to set to 80hz on the AVR itself and use Bypass on the sub.
Their suggestion is trying to cover all bases for those running multi or 2 channel systems.
W
Wardog555
Short answer is absolutely yes.
I do this myself. I don't know of a single person who does it differently
