Subwoofer level/calibration help.
K
Kyle Braunlich
To my understanding you should have the subwoofer level set to -8 to -6 dB in the levels for each speaker after Audyssey calibration. Then you increase the gain to a point to your liking after audio calibration. In my receiver, Denon x1400h, in the surround parameter settings page I can adjust the subwoofer level again. I am not sure what is the best for each settting. High gain and low levels is what I think is best so the receiver is not stressed but I don’t know if that messes with balance.
K
Kyle Braunlich
Also, what would the best distance settings to try. I notice a difference when chasing it on the subwoofer, but not sure if I am doing the right thing.
ryanosaur
ryanosaur
Audyssey should be asking you to set your gain to about 73/74dB prior to testing. I’m not a big fan of the room correction, but I wanted Audyssey to set distance and levels, which it usually does well. Unless u have something wired going on, your sub distance will probably read further away than they actually are, who’s is fine: a result of their on-board dsp. After testing though, my subs were too hot, so I had to adjust both my gain and avr trim down. I did this by ear so that upright bass sounded in balance with other instruments. I did not adjust the speaker-level setting, rather the subwoofer level setting (I’m on a Marantz, should be similar, I think). In the end, I also turned Audyssey off, just keeping the levels and distances.
Your bass preferences may vary. ;)
Likewise, depending on your subs and room size, you might need them set hotter.
YMMV
K
Kyle Braunlich
YMMV
Thanks for the info!
