.....Xizar, you've got a 2 channel receiver, is that correct?....if so, your only option is to send the full-range signal to the powered sub out the tape monitor unless you have pre-outs and I've only seen that once on a 2-ch receiver....if your sub has a variable-cut to the ceiling of what you want for a sub signal, you're home....otherwise, you're going to have to employ a cut on the ceiling of the sub signal, or you won't care for the outcome, probably.....in the early days of trying to get out cheap for lows, I put a coil of wrapped wire inline on the plus speaker-wire right before the subwoofer enclosure....it had a magical effect of slowing down the highs and allowing the lowest frequencies to show up....seriously....uh-oh, here comes a few "NO WAY" posts, haha....I raise my right hand on, it made the highs and mids rolloff sharply, compared to the low stuff....this helped form a few theories about resistance.....
.....well, Xizar, I just went back and looked at your second picture....you're home.......
