this looks good .. but what do I know .. what doesn eveyrone think of this ?
Our Dayton subwoofer adds impact and realism to music and movie soundtracks with its tight thunderous bass. Perfect for small to medium size home theater or listening rooms. This powered sub features a down firing, front ported bass reflex design to produce deep clean bass. It utilizes a 10" long throw driver and a flared port to help reduce port noise. The 100W amplifier features gold plated high and low level inputs/outputs, phase reversal switch, volume control, auto on/off (activated by input signal), and a 12 dB electronic low pass filter that is continuously variable from 40 to 160 Hz. It also features a 6dB high pass filter (125 Hz, 8 ohm) output for satellite speakers. The MDF cabinet is finished in an unobtrusive "Black Ash" vinyl veneer that will blend in with any decor.
Specifications: *Frequency response: 25-160 Hz *Exterior dimensions: 12-5/8" W x 16-7/8" H x 15-5/8" D.
100 watt subwoofer amplifier w/ 10" long throw woofer
Perfect for small to medium home theater or music systems
Unobtrusive "Black Ash" finish
Net weight: 40 lbs.
Normally you would have to pay over $220 for a full-featured 10" Subwoofer with 100 Watts of power!
http://www.*****************/pe/pshowdetl.cfm?&DID=7&Partnumber=300-632
