Subwoofer for HT $200 or less.. use or new help!
bustaf00
:confused: I have a budget of $200 on a sub maybe $250 at the most.... Doesnt matter new or use like from ebay... but what brand, make and model is good for HT. my livingroom size is 17w X 14d X 8H i perfer going with something like 10" woofer and up... any help Please... thanks :confused: :confused:
chaos24
how do you like your bass...what is it going to be used for more....h/t or 2 channel...best bass for the buck i think is a cerwin vega sub....or you could try a polk psw303....both should be in your price range
bustaf00
well the bass is a must... I am looking on ebay for some use one like velodyne, defenitive, paradigm, klipsch....any good model advise out of those brand...if not any more brands... thanks
bustaf00
All out Home theater sub.... maybe a little 2ch...audio... any help or advise.. how good is the Bic H100 .. thanks
Sheep
Sheep
BIC H100 and Cadence Xsub are the budget leaders. Personally, I would go with the H100 after reading this thread.
Next time, use the search. It will answer most of your questions.
SheepStar
bustaf00
Wow thanks sheep... after looking at that thread really pointing me to HSU... I guess that would be a good budget way.. but how about velo and klipsch comparing to Hsu..?
Sheep
Sheep
For the money, you can't beat the H100.
SheepStar
Polk's subs are junk. I'd say it was safe to go with the H100. There is also the X-sub from AV123 for $199 (only in shadow maple at the moment).
bustaf00
1st off Thanks all for the replys....I have found some H100 for $229 shipped...
I think that is a really good deal...so decided to go with the H100. Unless someone else can make me think differ...
Now I have another question. my set up right now is 2 Jbl L100T for the front and getting some klipsch ss.1 for the rear soon.. not sure the center no model or brand on it... but sound really good tho. receiver is sony thinking of going with pioneer vsx 1016... any advise... thanks
Buckeyefan 1
Buckeyefan 1
I bought a Cadence XSUB ~2 years ago for $189. It was roughly the H100, minus the huge surround but with a more powerful amp. If I could go back in time, I'd probably spend the extra and get something like this:
http://www.hsustore.com/stf2.html
My room is roughly the same size as yours, but it opens up to a kitchen and dinette area, and really needs a larger sub. The STF 2 would sell much easier and for closer to the retail price than would a H100 or XSUB should one want to upgrade. It's hard to justify spending the extra at the time of purchase, but when you look back, most always say "I should've went with the better product." Now, if your budget is max $250, then your decision is fine. It's just hard to realize how much better these $400 - $500 subs sound than the < $250 subs.
Tomorrow
Tomorrow
Why do you prefer this sub over the Infinity? For roughly the same price you get a noted brand name and twice the amp power (150 vs. 300 watts RMS).
Nice front speakers, btw. :)
EDIT: A JBL EC35 would go smashingly with your mains.
bustaf00
Thanks for the reply guys..:eek:
To answer your question Rj.. With all the reviews from user to Prof. pointing me to H100. for one they all say the same thing for the price sounds like a $400 to $600 sub... the looks and styles looks great:D :D
For infinity, i get a lot of mix reviews on them from other user, can't find a Prof. review on them... Btw thanks about my JBL L100T vintage stuff lol.... still sound pretty good :D :D dome tweeter 4"mid and a 12" woofer rock the house lol...hehehe:D
Buck thanks for the infor. on the Hsu... I have seen them, but just can't come up with anymore money... maybe later on...but not right now. :mad: :mad: If i can find them in the $250 range would be :D :D
Can anyone tell me if the Klipsch SS.1 a good surround speaker... because i am going to buy them today... for $139 new... remember budget right now...
thanks
