E
Energize
Hey guys,
I recently have created my own DIY subwoofer with help from the forums. I ended up following the plans for the infinity kappa's, which seem to be pretty popular within the forums. It seems to preform quite well, but i am wondering if adding an EQ to flatten the curve would benefit the response. I would obviously have to invest in some DB meter's and plot out its curve as per my room, but does an EQ for your subwoofer actually make that much of a difference in terms of reproducing the lows as was meant from recordings?
In particular i was looking at the Behringer Feedback Destroyer Pro DSP 1124P, as its parametric 24 band customizable. Seems to fit the job of a subwoofer better than most others, especially graphic EQ's (as they usually only go to 20Hz, and you cant control the bandwidth or anything else). Will this unit allow me to program in the EQ settings i need throughout the lower freq. rage (ie 15-200hz), and for $100, is this a good deal? Im not a huge HIFI nut by any means, but i do know my way around most things audio, any help from you guys would be great.
If you need to know about the woofer\box itself, i have the 12.1 perfect powered by a 300W plate amp. The enclosure is about 4.05 cu ft, with a nice big slot port out the rear, heavily dampened with rockwool. I found the design for it on this thread actually, and your advice to others seems to be top notch!
E
Energize
Oh, one other thing, with this unit, am i able to specify several points on the low freq scale to control? For example, i could set gain @ 20Hz, reduce @ 35Hz, gain @ 50Hz, and so on? From what ive seen, many PEQ's just have one low end band (20-200), which would be fairly useless for subwoofer applications. Feel free to educate me on the subject, im all ears...
Warpdrv
Warpdrv
Hello Energize....
Congrats on the completed build.. I think you should post some pics...
The 1124 will do such things for you, but will require some involvement.
Home Theater Shack has a great place to do all your research for using a BFD to control and EQ your Sub... http://www.hometheatershack.com/forums/bfd-forum/ and use REW for running sweeps to help you measure your rooms response, unless you already have the tools to do such measurements... that is here... http://www.hometheatershack.com/forums/subwoofer-equalization-calibration/
What you need is a computer with a sound card, not a mic in on a laptop as it will not work, and you can get away with using your Radio Shack meter to do the measuring in conjunction to on screen with your computer running REW(Room EQ Wizard).
One thing I suggest is that you do not use the EQ to boost, but only cut, and then you can use the gain to bring the level up after smoothing out the response.
E
Energize
Warpdrv,
Thank you so much for the reply. After reading the posts from the "Shack" I've already ordered my BFD. Can't wait to get it and start the whole process. Unfortunately i plan on moving in a year or so, so i will have to do it all over again, but setting up a dedicated HT room will be an amazing experience. I can't wait to see the monstrosity of a room effect im getting in this place, it will put the BFD to the test!
