Question that was asked - Which I thought was a good question by Jostenmeat -
We can all sense differences in output, and can hear differences in decay/overhang, but what distortion levels/percentages are discernible to us with LFE frequencies, and just how far beyond these thresholds do horns get to? I mean I read up on the Fitzmaurice folded horn, and sub-5% distortion . . . is that even perceivable with LFE (honest question)?
You will hear different answers....but at 20Hz, I can hear the difference between 5% and 10%, and below 3%, I can't tell anything.
Quoted from Monte Kay's page:
http://www.mfk-projects.com/theatre_woofer.htm
While it is widely accepted in the industry that non linear distortion at low frequency is not particularly audible I am convinced that it is audible. In fact I believe that non linear distortion is the most audible at low frequency. One look at the equal loudness curves of human hearing should convince anyone that non linear distortion is least audible above about 3 KHz and most audible below 3 KHz. Above about 10 KHz it should be completely inaudible because the 2nd harmonic is exceeding the human hearing range. At 20 Hz the human ear will hear an equal level 40 Hz tone as 20 dB louder based on a 90 dB reference level. This means the 40 Hz harmonic must be 20 dB below the 20 Hz fundamental just to sound as if it is the same level or 100% 2nd harmonic distortion.
It's very difficult to achieve low distortion at frequencies in the 20 Hz range. Consequently I wonder how test were conducted to produce the widely held belief that distortion is inaudible at low frequency? Since most woofers produce at least 10% distortion at 20 Hz which sounds like 100% distortion at the 2nd and far higher at the 3rd, they have no clean reference to determine if induced distortion is audible. The test platform is starting with too much distortion to begin with for anyone to assess that an induced distortion is or is not audible.
Until you have a clean reference, you cannot tell.....
