Sounds like you definitely took advantage of SVS' in home trial policy so thank them (and their customers
). Did the PC model fit better or you just preferred it aesthetically? So located in same position you felt it was significantly different? Interesting....
I liked the form factor and weight of the PC better over the PB. And, I was surprised they sounded different. (And I did recalibrate with Audyssey and then did manual adjustments to make sure that wasn't the issue.) Perhaps it was because the front firing PB was able to avoid sound reflections the downfiring speaker couldn't?
Upfront - where the subwoofers can fit - there is a TV stand on one side and bookshelf or wetbar cabinet on the other side which creates an alcove. Perhaps the forward firing sub avoids acoustic issues from this alcove?
We just tried the PC behind the couch yesterday, and it seemed to sound much closer to the PB there. But, I think with my room layout, the upfront PB still trumps the behind the couch PC. (Upfront seemed to be slightly better during the subwoofer crawl too.)
Even though the PC would have been an easier fit, I can still fit the PB well enough and it is a bit cheaper if I ever decide to add a second. (Girlfriend is already lobbying for the second, lol. I'm a lucky guy.)
Thanks again to all for their help on this. I would not have ordered the 2000 pros to try when they restocked for the sale if it weren't for this forum.
