markw,
Where do you see a knob that says 0-150? There is simply a label below the input. Obviously the first thing I thought of was the sub has its own crossover and a knob to set it like nearly all subs I've seen. I don't see that, unless it is hidden from view.
Cyclop,
Sorry for the confusion. I see only inputs for cd, dvd, etc and a few line outs. So my info still holds. You will need an active cross-over between the out1 and the sub. The ICBM is such a device and I've seen them alot cheaper than $250. A cheaper alternative may be available at Radio Shack or other electronics stores.
...Unless your sub does have a crossover setting knob which is just not visible...as markw assumed it does.
