W Walt Moody Audiophyte Mar 2, 2017 1 0 1 53 Mar 2, 2017 #1 I'm looking for the best way to connect my JBL Dominion sub to my NAD D3020. The processor has 3.5mm sub output and the sub has stereo RCA inputs. Suggestions? Thanks.
j_garcia Audioholic Jedi Jul 11, 2005 32,531 0 113 Mar 2, 2017 #2 yes, any 3.5mm to RCA adapter or cable should work. Sub is mono, so it doesn't need both inputs in most cases.
TLS Guy Audioholic Jedi Oct 30, 2007 27,300 0 113 79 Eagan MN Mar 2, 2017 #3 You will need a mono 3.5 mm plug. That means tip and body, no ring. There should be one RCA plug on the other end which should be plugged into the left input on the sub.
