jeffvee
Good Idea HI HO,what type of tool is needed to attach the connectors :confused:
Z
zumbo
WmAx said:
If you mean the diameter of the metal wings that grab the outer metal cylinder(ground), then if they are loose, the fix is easy to impliment using common pliers.
-Chris
Where did things go wrong?:rolleyes:
Errrrrrrrrr!:eek:
http://www.bluejeanscable.com/pages/technicaldocs/canarercap.pdf
http://www.radioshack.com/product/index.jsp?productId=2102841&cp=&pg=1&kw=rca+plugs&parentPage=search
It's hard to see from the picture of the Radio Shack plug, but the outer ground is a thin round piece of metal that is slotted. It is a poor design compared to the Canare design.
Hi Ho
Hi Ho
If you buy the cable at a place like RadioShack you can either buy a preterminated cable or bulk. They will probably crimp the connectors on for you, otherwise you would need a crimp tool. The adapters, seen HERE, simply screw on.
There are also twist-on connectors, which I like best. You need no tools for those.
You can also buy crimp on RCA terminals.
WmAx
WmAx
Errrrrrrrrr!:eek:
The Canare is pretty, but the RS plug is perfectly functional. If you want to buy plugs for the purpose of cosmetic appeal, then I recommend the Canare over the RS unit you linked. If you want a functional plug, I recommend the lowest price of the two; or even better go to partsexpress and buy some for much lower cost than either of these.
-Chris
K
kelly
sub cable
I have had a 15" velodyne for about five years, and have been using a 20 year old radio shack plug in it, and it was ok. I found an audioquest sub X sub cable at the store that was normally $50 but the box had been opened and they had it marked down to $25 so I bought it, and did hear a noticable improvment in the subs overall sound. I know most people on this site think expesive speaker cable is crap, and for the most part I would have to agree. I did buy expensive cable for my fronts, and heard little or no difference. But I did hear an improvment with the sub cable. Take it or leave. Just food for thought.
