bdub
<font color='#000000'>Do the expensive sub cables provide any better performance than the single-line rca cable I bought for a few bucks?
Thanks.</font>
<font color='#000080'>You want a nice shielded sub cable, but you don't have to pay tons for it. If you want to make one yourself, I have heard that RG-6 quad-shielded coax makes a great home brew solution.</font>
Y
Yamaman
Are there absolutely no issues with using RG6 as subwoofer cable? I ran a line anways because I just can't afford the standard sub cable since I'm looking at a 40' run
tedmjr2
I have a 35' run of RG6 to my subwoofer with no issues. In my experience, there's no audible difference using the name brand subwoofer cables. If you can afford the cost and prefer to purchase retail, your satisfaction and happiness is what counts.
sheep
Guest
bass 100 cable
you should not have to spend that much for a cable, as matter of fact, the minimum thx certification subwoofer calbe performs better then my monster bass 100 and its cost about 15-20 dollars more.
sheep
RG 6 type or as JohnA posted, you can link two from partexperss that is long enough for you. I'd go for either if the price is close enough, or the lesser cost if it is a lot different ;)
Y
Yamaman
Well, I purchased RG6 at $0.25 a foot from my favorite HT store. Good quality cable and dirt cheap! :D
That's close to free :D Them may even pay you to take it ;)
