Hi Cabling Experts:
Question on subwoofer cable and "signal flow":
Currently I am framing a room in my house for home theater. I have finished running all speaker wire and after finishing off routing my last speaker cable: a Monster subwoofer cable (about 7' run) from receiver position to corner of room where sub will be located.
Once I was complete I looked at the cable and noticed a "signal flow >>>" notation on the cable.
Naturally as as you have guessed by now I reversed the cable - the signal flow as it stands now would be from sub to receiver. I have never heard of "signal flow" before - is this really a big deal, will it affect sound/performance??. I can fix this with about 2 hours work (drywall, tape and sand, repeat as needed...) but I'd rather not to be honest.
Question - does signal flow direction matter with sub cable, do I need to reverse the cable as currently installed??
Thanks
