Subwoofer Cable Interconnect Question
jmsalt1
If you are running two subs, in my case I will be using two Velodyne SC-600 IW's along with the SC-602 Amplifier, should the sub cables be the same length or is that a non-issue if they are under a certain length? I have not ordered them yet so I am asking in advance of making a purchase from Blue Jeans Cable. If the difference in cable length is only a few feet does it make a difference? Is there a point where the difference in length for the runs to two different subs. becomes an issue?
JerryLove
JerryLove
The signal travels just a little less than the speed of light. A few feet will not make a difference.
jmsalt1
Thought I was being a bit paranoid but at the speed of light, clearly no worries over 5 ft. of cable. :D
