Hello Everyone,
I need a subwoofer driver & amp recommendation for a sealed 93.4L oak veneer cabinet (15.5"W x 28.5"H x 17.75"D). It has a 1" front baffle and 3/4" High Density Particle Board with solid oak corner blocks. There are no cut-outs yet, so I have flexibility in choosing driver size, 2 drivers versus 1, and plate amp versus external amp.
My room is very large at >3,000 cubic feet, plus it has the typical open floor plan configuration with another 2,000cf kitchen. The objective is musical extension below the mains (JSE Infinite Slope Model .6) with 8" woofer rolling off between 35-40Hz. High SPL is not a priority, since I never listen to music or movies above 90 dB.
I've looked at the Madisound NHT 1259 kit and the Rythmik dual 12" driver GR Research Servo Kit. However, if there is a better subwoofer-amp combination for this cabinet I would like to know. My budget is $350 - $650.
Thank you.
Ward
