Subwoofer amp. cable question
deviley
My receiver has a single RCA jack and the Sub. amp. has the double RCA jacks. the "Subwoofer cable" I just ordered is only a single on both ends, is there an adapter for the Amp. end or is there another way to hook up with the single ended cable.
N
Nick250
You really only need to connect the sub cable to one of the two rca jacks on the sub. If your sub has an "auto on" feature you might consider getting a one into two adapter so you are using both connections on the sub to give it a slightly stronger signal to ensure the auto on activates on que. That's what I do.
Nick
deviley
thanks
thanks alot Nick I appreciate the info. my sub. amp. does have the Auto setting. I will have to make a Radio Shack run. thanks again.
