SubSonic 6i Makes a Weird Noise
Ares
Ares
Hey Gang, I have a question my sub has been making this noise it sounds like a sub that has been put in a trunk of a car and the trunk lid has that awful rattling noise when they don't use Dynamat for the lid. I was wondering if this is normal? Also I noticed that air is not coming out of the port any suggestions on what might have happened here and how to fix these issues
Thanks Guys.
Captainmorgan89
Sounds like you blew the sub. Basically, that sound is called "bottoming out". Its a loud clicking sound, and its definitely not good.
Ares
Ares
I haven't heard a clicking, the sound is more like when windows rattle from heavy bass music.
3db
3db
Are you sure its from the sub and not from something being rattled by the bass? Do you have small children? If so, may something was inserted into one of the ports.. If its none of the above, I woould think that the sub is damaged.
Ares
Ares
It was a rattle, I called S.A. and told them what was happening and they said to bring it in, which I did yesterday come to find out that there was a few screws that were loose connecting the driver to the box. I was still under warranty so they just gave a new sub, so no more rattle.
3db
3db
Awesome!! Good for you:)
