Sub to match B&W CM9s?
d9999
What would be a good sub to match my setup?
CM9s fronts
CM Centre 2
CM1s surrounds
The subwoofer that matches the set is the B&W ASW 10 which is $1,500.
Do you think I should just buy the matching sub or get a different one?
I have a 10x20 room, and movie and music sound quality is most important for me. Brands or specific subs are welcomed! Thanks in advance!:)
You don't need a sub to "match" your speakers, you just need a good sub. No, I probably wouldn't buy a B&W sub either, especially not for that price. For that price you could get TWO excellent subs.
Take a look at the typical recommendations: Rythmik F12, Epik Empire or Legend, Emotiva X-Ref12, HSU VTF-3, SVS, etc... ANY of those should do well in a room that size.
d9999
Wow, some great recommendations! I will definitely look into those.
d9999
Anybody else with any recommendations? Or have a favorite from the ones he recommended?
agarwalro
agarwalro
With a $1500 budget, I would recommend getting 2x subs. It will be easier to get flatter FR in more listening positions. Or, you can stack them in a corner and get more output than one of same Dollar amount. Best would be is you get a $1500 sub now and add a matching one down the line :D.
From experience I can say the SVS subs are bullet proof. My PB-12 Ultra would easily pressurize a 20x25 space. At $1200, the PB-13 Plus looks great.
annunaki
annunaki
Moderator
Dual Rythmik subs would be a good match for your setup there as would these following options:
You could also look into a pair of these at that price: RS1200K kit
Or even a pair of these!! RS1202K
robc1976
Totally agree with that...Also check out Elemental desin as well as the ones the OP suggested....all good subs.
