Hey there,
I am currently running a pair of Ascend Sierra-1s with an Outlaw RR2150 (100wpc - 8 ohms/160wpc - 4 ohms). While the system sounds very good, I am looking for more deep bass response for my 2-channel listening. I've been looking into purchasing a sub to fill the bottom end. I've checked with Ascend Acoustics and they recommend using the Rythmik Direct Servo sealed subs (they sell), which they told me integrated well with the Sierra-1s. I've started to look at SVS and Hsu too. I wanted to get some opinions on subs, cables, and placement recommendations. I'm running this system in my 23x14x8 living room which opens to 11x13 dining room. The living room is carpeted with about a 1/2 of padding underneath. I'm only using this system for music.
1) I've read about the issues with the RR2150's sub output being too low. I don't know if anyone is familar with this, but Outlaw has mentioned that they would modify the sub output voltage if necessary to correct this. Does anyone who had used an RR2150 know if there have been any issues with the sub out using a Rythmik sub? I'm looking at the F-12 SE. Here is a link to the specs for this sub:
Rythmik F12 SE Specs:
http://www.ascendacoustics.com/pages/products/subs/f12se.html
2) Would a 12" sub be sufficient to fill the room? I don't have that much room for too large of a footprint, but I wasn't sure if I would be compromising any sound by not going with a larger sub (15"). Feel free to recommend other subs as well.
3) Most subs have a a left and right channel input. Based on the F12 SE sub and specs provided, what would be the best way to connect the sub to the single sub out from my receiver? Should I use a Y-cable to run the mono channel into both the left and right channels of the sub from the 2150? Will this make much difference in sound quality?
4) Am I better off using the sub's crossover or the Outlaw 2150's bass management?
5) I'm only going to use this system for music. Am I better with a sealed sub to fill the room?
6) My room is pretty cluttered, so placement of the sub will be a challenge. I have some room in near corner of the room, but it would to be placed next to a curio cabinet or next to one of the front speakers. Any suggestions on placement?
I've attached a layout of the room with possible sub placement areas to help with this.
7) Any suggestions for sub cables? I've looked at the usual places: Outlaw, Blue Jeans, Cables to Go, BetterCables, Cables 4 Less, and Best Deal Cables.
8) The living room (2nd floor) is carpeted, so I imagine I would not need any vibration pads (subdude, gramma, etc.), unless I went with a downward firing sub?
Didn't mean to ask so many questions at once. Any suggestions would be greatly appreciated! Thanks all!
