Dear all,
Tonight I was watching a DVD and was almost at the end of it when I heard a 'bump' noise from my sub which I was fairly sure was not part of the soundtrack. A few minutes later, it came again. At this point, having already turned down the volume, I switched everything off.
Starting the process of troubleshooting, I replaced the DVD with a CD becuase the DVD was just bought and I wanted to see if the problem persisted with a CD I knew to be fine. It did.
Next, I tried using the coaxial digital as opposed to the i-link cable. Still the same. Then I used my old Musical Fidelity CD player instead of my Yamaha S2500 (which I currently use for both CD's and DVD's). Still the same.
By now, I know for a fact that the problem does not lie with my S2500, and must lie either with the Yamaha Z9 amp, or my sub itself. Since my CD does not have a LFE channel, I am reproducing sound from the sub by putting the Z9 into '9 channel stereo' mode. The thing is; when the 'bump' occurs, it does not come from any other speaker (i.e. FL, FR, C, SL or SR).
Do you agree that this means the fault must lie with the sub?
Regards
EDIT: I thought of a possible problem with my hypothesis; all my speakers were set to small. I changed my FL and FR to Large, but the problem, now much worse sounding still comes only from the sub.
I am now pretty convinced that it's the sub. Do you agree?
