Hello there. I have gotten tons of help from you guys in the past and thought I would try for some more answers.
I have an Elite VSX41 (yeah, I know, it sucks).
The problem is, that the sub output cuts out randomly. If I quickly unplug and reconnect the sub cable from either the receiver end or sub end, it kicks back on, but will cut off again at some time later. How long its on doesn't seem to be a factor. Nor does the level it's outputting (it could be in the middle of extended bass notes or during silence).
I have at first thought it to be the sub itself, but recently replaced with a new unit, only to have the same problem.
I am not averse to disassembling the receiver, and my soldering skills are quite good if it helps at all.
Before I start doing any actual work though, what are some opinions??
