Sub not working on 6 channel input.
Dean Kurtz
Dean Kurtz
Hi,
Long time since I've been on. I have a Denon 3910 and the sub does not work when I use the 6 channel input on my receiver for SACD. I use RCA cables for that. It works on everything else. Any ideas? Thanks.
Jeffrey S. Albaugh
In order to use the 6 channel input, you must connect all channels using analog RCA cables. It does not use Digital Optical cable.Obviously, you have not connected the subwoofer output from your Receiver to the Subwoofer input on the 6 channel sub in. This will fix your problem. You're welcome!
