Sub hook up question...
Cheapshot
Cheapshot
I just hooked up a pair of paradigm speakers to a 2-Channel bryston B100 integrated amp. There's two techics 1200's i/p to a mixer and o/p of the mixer to the bryston. The problem is there's only one o/p pair on the mixer and im already useing it for the amp and i want to hook up a sub too.
Is there anyway to run the sub and the speakers with this equippment?
3x10^8
3x10^8
Of all the mixers I've ever used, none have ever had a a specific sub output. I'm not familiar with your bryston , but would guess to venture that your sub would plug in through the amp.
Which mixer are you using?
What sub are you using?
Lastly, what do you spin?
Cheapshot
Cheapshot
Yeah i thought it would have a Sub i/p too but i cant see one.
1.The mixer is a Stanton SA3.
2. The Sub is an old model I had kickin around from an my dads HT system. Its a Sound Dynamics (200W i think) with 2 rca i/p's or bare wire can be used.
3. The tables are technic 1200's
Does the sub have internal crossovers? If not, you need an external, active crossovers before the amp.
Cheapshot said:
Yes the sub has internal crossovers.
Then, if you only have one speaker level in and out, or only one out try with one of the channels. Run to the sub and out to the speaker.
