There is still a trick in this...
Corner loading a Sub makes it Louder... not necessarily cleaner or better. Be careful to not fall for the common trap of believing louder sounds better. Listen carefully to the quality of sound rather than the quantity.
Clearly, something isn't right, though...
What you should be looking for when doing the Sub Crawl is clean bass, and hopefully where it matters.
I would try again, and use some different material. (What did you use when doing it before?) I found music works best for me, but others swear by pink noise and a few replay movie scenes.
For music, you want something that has some range to the bass, and hopefully consistent. I used Gorillaz
Laika Come Home which was not consistent, but had good range. It's trite, but Daft Punk
Get Lucky is a good cut as it is repetitive and all over the place.
It took me almost an hour the first time I did it, and it was crawling into and out of the corners that helped me start hearing what was really going on!
