sub for spendor 8se
mizuno
Hi,
what sub would you recommend for a HT system built around the spendor 8se?
Any advice? Looking to spend less than $1000-1500.
Thx!
jf
mizuno
forgot to add
room size is about 2500cubic ft. ideally like 10'' sub or more.
AVRat
AVRat
Is size or aesthetics an issue?
SVS PB12-Plus / PC12-Plus / PC-Ultra
AV123 MFW-15
HSU VTF-3 MK3 / ULS-15
Epik Caliber / Castle / Tower
mizuno
size or looks
Yes a bit.
My ideal ideal would be between 10 and 12'' woofer, cherry finish, very dynamic and good staging. ok of it can be easily be found used and fall under $1k. Was thinking rel or linn sizkim,... Not sure if velodyne minivee 10 is good enough....
