I
IJinfinity
I have this bass guitar amp witch i dont use, so i was wondering if it was possible to set this up as a subwoofer in my home theatre system.
the amp got an 12-14" woofer and two bass ports. i found a jack input on the back where it stands "speaker 4 ohms".
does anybody know how to set this up properly?
baniels
baniels
I searched google for 'bass amp as subwoofer' and found some discouraging things. The freq response of the typical bass amp doesn't reach very low. Even if you can figure out how to properly get a signal into it from your sub-out, it probably won't be that satisfying.
That said, you can always try it and see. Do that search on google, you'll find other who have done this.
