Hi guys, first post here, so a bit about me first!
I built a HTPC a couple of years ago and have been hooked on DIY AV stuff ever since, since its been a massive success with the WAF sky high. Documented my journey from AV noob to someone who knows a bit more than average on a blog buildingahtpc.blogspot.com.
Massively increased my committment to DIY AV by taking on a Tony Gee LBS floorstander design over 6 months back and finally completed them (well almost) in partnership with a HifimeDIY TK2050 amp. Turned out to take longer and cost a lot more than expected, but the result is amazing.
Since I've now thoughly hooked myself on the hobby of DIY Hifi, I wonder whether anyone can help me... I've posted over at DIYAudio, but my thread hasnt got any traction for some reason.
I'm planning out a subwoofer build to match with the pair of Tony Gee LBS floorstanders – since I bought all the tools and stuff to build the floorstanders, adding new speakers will be relatively cheap (thats what I say now... ask me when its finished
) – and first cab off the rank is a subwoofer!
I would have liked to build the Passive Radiator sub using the now discontinued Peerless XLS PR, but since I can't reliably find them anywhere, I've been experimenting in WinISD Pro with a Scanspeak 26W/4558T00 driver and the matching passive radiator 26W/0-00-00 – apparently 'newly released' and sold by WES in Sydney.
Sorry - can't insert links until my post count goes up, but here are the URLs, replace * with .
www*scan-speak*dk/datasheet/pdf/26w-4558t00*pdf
www*scan-speak*dk/datasheet/pdf/26w-0-00-00*pdf
Has anyone built a Passive Radiator design with these Scanspeaks? I heard that the max excursion is not great in the Scanspeak, and I understand that Xmax measurement can be a little inconsistent between manufacturers – but the Scanspeak value of 28mm actually exceeds the Peerless 22mm.
I plugged the stats into WinISD and chose a box size of 30L and added 200g to the PR (as per the similar Peerless design) – the graphs come out like below for the Scanspeaks:
As I'm not yet adept at knowing what I should be looking for in these charts – I wonder whether someone whose done it before would be kind enough to comment on whether this design would be a goer, or whether I've overlooked something catastrophic in the graphs or in entering the parameters. It looks good to me, but only because it seems similar to the Peerless results and doesn't seem to blow up in excursion.
Scanspeak 26W driver in WinISD:
//img710.imageshack.us/img710/7025/scanspeakdriver.jpg
System Transfer function:
//img685.imageshack.us/img685/7227/120wn.jpg
Passive radiator transfer function:
//img10.imageshack.us/img10/2104/prtransferfunction.jpg
Passive radiator cone excersion @ 120W:
//img339.imageshack.us/img339/8707/prconeexcursion.jpg
Driver cone excursion @ 120W:
//img405.imageshack.us/img405/8705/driverconeexcursion.jpg
Any comments appreciated!
thxs, b
