i know that for home theater use, you generally need at least a 10in sub to get deacent bass, 12" or 15" is even better. however, i have an 8in woofer, with a relatively high x-max(.39in), fs of 33.1hz, vas .79 cu ft, and 125w rms power handeling. what would be the best set up for this in a home theatre system? would a properly designed box with a passive radiator provide enough bass in an average sized living room? i haven't found much about passive radiators and was wondering if the 8in sub, when combined with a passive radiator, would be a better choice than trying for a ported enclosure with the same driver??
thanks for the help
